1. Highlight the area in the Worldwide Menu where the new area should be added 1
In this example, a station will be added to Washington.
Profile-Add-Area-1
2. Click the ‘+’ button at the bottom of the Worldwide Menu 2
This will bring up the ‘Add Area’ screen:
Profile-Add-Station-Menu
3. Select “Station” on the ‘Area Type’ menu. 3
This will display the station configuration options:
4. Enter the station name 4
5. Select the Applications that apply for the station 5
N.B. Applications will only be visible if they have been purchased and activated in the key.
6. Select the number of Meter Runs 6
If the station is handled by a single stream RTU then this will generally be one.
If the RTU is a multi-stream flow computer then extra options will be available for station and prover. If the flow computer has a station and prover built into it then tick these checkboxes 7.
If the station has tanks, ticks the ‘Tanks’ checkbox and add a tag for each tank on the station 8.
7. Click the ‘Save’ button 9
The new station will be added.
See the ‘Adding an RTU‘ section for more details on how to add an RTU to a station.
