This only needs to be done if the RTU has a field type that does not appear in the default list.
Note: Choices for the next options in this section will vary depending on the type of field selected.
| Number of Bits | The number of bits to use for the register. This is only used for integer, floats or doubles. |
| Number of Bytes | The number of bytes to use for the register. This is only used for strings. |
| Number of Registers | The number of registers to use for the Modbus address. This is normally set to 1. |
| Reverse Byte Order | This checkbox indicates whether the bytes in the register should be reversed. The bytes are not normally reversed. |
| Reverse Register Order | This checkbox indicates whether the register order should be reversed. The registers are not normally reversed. |
| Signed | This checkbox indicates whether the integer should be signed or unsigned. It only applies to integer fields. |
