See the Adding a Field to a Configuration section for more details.
The security level can be either “None”, “Everyone”, “Operator”, “Technician” or “Administrator”. If the user has corresponding access in their access privileges, (see the ‘Adding a User‘ section) then they will be able to edit the value of the field in the RTU (see the ‘Changing Set Points‘ section).
Tip: Real time values should always have their security level set to be “None”. This means that no-one can edit the value of the field.
