Fields can have formulas associated with them to allow simple arithmetic functions to be applied before they are displayed or written to.
See the Adding a Field to a Configuration section for more details.
Formulas have the following syntax:
value:=expression
where expression is a mathematical formula, e.g.:
value:=9*4
Any field from any of the RTU can be selected and can be included in the calculation, e.g.:
value:=field("Pressure")
Multiple fields can also be included in the calculation, e.g.:
value:=field("Net Flow Rate")-field(Gross Flow Rate")
Variables can be declared and used as part of the calculation, e.g.:
var a := 2; var b := 3; value := a + b;
If statements can also be written to display a value based on a Boolean expression being satisfied.The following formula returns how far a value is outside of its two limit fields:
var temperature := field("Temperature"); var high_temperature := field("Temp Hi-Lim"); if (temperature > high_temperature) value := temperature - high_temperature; else var low_temperature := field("Temp Lo-Lim"); if (temperature < low_temperature) value := temperature - low_temperature; else value := 0; end if end if
The calculation can include any of the following operators. A full list is available in the operator popup menu.
+ | Plus |
- | Minus |
* | Multiply |
/ | Divide |
% | Mod |
\ | Integer Divide |
= | Equals |
# | Not Equal to |
< | Less Than |
> | Greater Than |
<= | Greater Than or Equal to |
>= | Less Than or Equal to |
|| | Logical OR |
& | Logical AND |
| | Bitwise OR |
&& | Bitwise AND |
<< | Rotate Left |
>> | Rotate Right |
! | Not |
? | Bit Test |
“value:=value/100″
If the formula is entered correctly a message will be displayed saying “This formula is OK!”.
Note: Write Formulas are exactly the same as read formulas except that the variable used to write the return variable is “writevalue” rather than “value”. The line requires a “;” at the end of the formula. e.g.
writevalue:=writevalue*100;
This will return to the main configuration page.
This make the configuration changes active.
