If you’d like to have maps on your system please contact Ambrit. The map consists of two files, one a picture file and the other a text file.
Note: This should be a JPEG or GIF file.
This should be a text (.txt) or map (.map) file.
Important: Maps will only be enabled if there is a map defined for the top level area.
See the ‘Navigating Using the Map‘ section for more details.
