Major Updates
MET-443 – New template added “Equipment External Calibration”
This template allows external calibration information, test certificates, to be stored against field equipment. (It work’s in the same way as the existing “Calibrate Test Equipment” template works with test equipment.
MET-444 – Allow Calibration templates to be setup against equipment in Stores.
It is now possible to setup a calibration against a piece of equipment while it is in stores. Calibrations performed in Stores will be visible in the historical tab while the store is selected, or the equipment, even after the equipment is moved onto a tag.
MET-449 – Equipment Parameter Change Logbook Entries
Previously these entries have been visible only at equipment level. This has been changed, so these entry types are visible at all levels.
Minor Updates
MET-448 – Locked Store cannot be edited.
It is now possible with the “Edit Locked Area” permission to edit locked Store names.
MET-447 – Display Units File information
Details of the units file in use are now shown in the template admin screen. (At the top of the page.)
MET-446 – Locked Areas cannot be edited.
It is now possible with the “Edit Locked Area” permission to edit locked Area names.
MET-436 – Set mail server in preferences
It is possible to set the name of the mail server to be used and override the default mail server, which is the mail server for the domain of the message being sent.
MET-432 – Additional calculation added for CALIB054 & CALIB055
This version of the application is required when using v3.4 or higher of CALIB054 or CALIB055. These templates use additional formulas which are included in this update of the application.
