N.B. FLOWCAL functionality requires a non-disclosure agreement with Quorum Software.
Profile supports the CFX, PFX and TTF export formats, enabling data to be exported directly from flow computers and other RTUs in the field straight into the FLOWCAL application for accounting and further analysis.
Profile’s unique interface makes it simple to create templates that define which fields need to be exported to mirror an RTU’s archives. Once a template has been set up it can then be shared across multiple RTUs that use the same Profile configuration.
Daily CFX template | Generates a periodic CFX file on a daily basis |
Meter CFX template | Generates a batch CFX file when a batch ends |
Receipt CFX template | Generates a batch CFX file for the receipt meter when a batch ends |
Virtual CFX template | Generates a batch CFX file for a virtual meter based on the active flow path when a batch ends |
PFX template | Generates a PFX file for each prove |
TTF template | Generates a TTF file for a tank on a daily basis |
Exported FLOWCAL files are stored in the ‘flowcal’ folder on the Enterprise or standalone Profile server. Separate folders are created for each template type, date and meter.
Setting up FLOWCAL exports requires configuration in several areas. See the following sections for more details:
