See the ‘Accessing Server Settings’ section for more detail.
The Prover settings screen is displayed:
N.B. Some options will only be visible if they have been purchased and activated in the key.
Start Prove | Allows a user to start a prove in the flow computer directly from Profile. |
Add Prove | Allows proves to be added to Profile manually. |
Implement Meter Factor | Allows the meter factor to be written back to the flow computer. |
Collect Prove Run Data | Allows the data from prove runs to be collected in addition to the primary prove data. Prove run data is only available when using a direct connection or a VIA. |
Band Products by Flow Rate | Splits the product into high, medium and low based on the flow rate. |
N.B. Click the ‘Apply’ button to save the changes and remain in the Settings section. 4
