This will show the latest proves from each meter run:
This will show a history of all proves for the selected meter / product / base curve:
Each prove will be listed in chronological order, with the most recent prove first. This will show the prove date, the prove ID, flow rate, reproducibility, K factor and Meter Factor for the proves.
The status column will show the test status as a pass or as a fail and whether the prove was implemented or aborted.
By default the product from the latest prove will be selected. To see the prove history for other products, select the product in the ‘Product’ popup menu.
By default the latest base curve will be selected. To see historical base curves, select the older base curve in the ‘Base Curve’ popup menu. If the meter has just been replaced or recalibrated then the current base curve may not contain any proves yet.
The prove history will always show passed and accepted proves.
Use the ‘Show’ checkboxes to include unaccepted proves, failed proves, aborted proves and strikethrough proves in the list.
Clicking the ‘Export’ button will export the current list of proves to a CSV file.
Click the ‘Add’ button to manually add a new prove record.
